So...... I recently bought a liquid cooler (Mars Gaming ML240) for my pc but I didn't notice that my computer case didn't have a place to put it. So now I'm buying a new one where I can install this cooler. I found one from the same brand of the cooler that isn't too expensive and also seems to fit everything I need inside, but given that I've already messed up twice (which is enough for me to ask for help), I would appreciate some help just to verify that the case is compatible with everything on my pc and that everything will fit nicely, or case suggestions (bellow 70€) if you want to.
The case that I have in mind: https://es.marsgaming.eu/en/cases/mca-gaming-midtower_mca
My pc components:
Motherboard - ATX ASRock B460 Pro4
PSU - Nox Urano TX 850W 80 PLUS Bronze Edition
GPU - NVIDIA GeForce GTX1660 (https://www.biostar.com.tw/app/en/vga/introduction.php?S_ID=268)
CPU Cooler (the one I want to install) - Mars Gaming ML240 (yes, it is compatible with the socket)
RAM - Corsair Vengeance LPX 16GB (2x8GB) DDR4-3000MHz CL16 (yes, I am aware that the motherboard doesn't support this frequency, but it detects it has a lower frequency RAM)
Hard Drive - 3.5" Toshiba X300 Performance 4TB 7200RPM 128MB SATA III
PS: I have checked if everything fits but I want to be 100% sure before buying it.
https://linustechtips.com/topic/1360880-help-with-buying-a-case/
The Phanteks Eclipse P300A https://pcpartpicker.com/product/crqBD3/phanteks-eclipse-p300a-mesh-atx-mid-tower-case-ph-ec300atg_bk01
is a pretty good cheap case with great airflow. I even think that it was featured in a LTT video or two (the case wasn't the main focus, it was just the one being used.)
I'll keep it in mind thanks
