Budget (including currency): $800
Country: US
Games, programs or workloads that it will be used for: Apex Legends/War thunder/ Basically shooter games and Warthunder
Other details Running this at least 1080p Medium-high settings
At least 16 gb ddr4 3600 mhz ram/Or 32 gb 3200-3600 mhz ddr4 ram
Apu's/ are allowed
https://linustechtips.com/topic/1360365-help-for-800-pc-build/
That's a very tight budget for a gaming pc, especially these days. Skimping on features such as a decent case, motherboard or PSU etc. will end up backfiring when you choose to upgrade later on. I would recommend either waiting (till GPU prices drop) and saving up a bit more, or taking a look at avaiable prebuilts or used hardware if waiting is not an option. An APU won't give you great performance at 1080p med/high.
https://linustechtips.com/topic/1360365-help-for-800-pc-build/#findComment-14898779
Hello... I was able to Part out this build for you, Link Here
I have given you a Ryzen APU which has the best Graphics without a Video Card. Also the Power Supply I chose is big enough to add a Video Card when you can afford one and this build has 32GB RAM. The Case I chose has a full Mesh front panel comes with 3 RGB fans to help cool the system. The stock cooler for the CPU is more than good enough as long as you don't overclock the CPU too much.
CPU: AMD Ryzen 5 3400G 3.7 GHz Quad-Core Processor  ($304.99 @ Amazon)
Motherboard: ASRock B550M Phantom Gaming 4 Micro ATX AM4 Motherboard  ($89.99 @ Newegg)
Memory: Silicon Power XPOWER Turbine 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($64.98 @ Amazon)
Storage: Team T-Force Cardea Zero Z330 1 TB M.2-2280 NVME Solid State Drive  ($98.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($55.49 @ Amazon)
Case: Cougar MX330-G Air ATX Mid Tower Case  ($54.99 @ B&H)
Power Supply: ARESGAME AGS 850 W 80+ Gold Certified Semi-modular ATX Power Supply  ($69.98 @ Amazon)
Total: $804.39
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://linustechtips.com/topic/1360365-help-for-800-pc-build/#findComment-14899665
