Budget (including currency): 800 CAD (Up to 1000 CAD)
Country: Canada
Games, programs or workloads that it will be used for: Minecraft and Daily Browsing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://ca.pcpartpicker.com/list/YkgrK3
This is the part list I have currently. My budget is $800, but I'm willing to spend $1000. If you have any advice, comment it down below. I want to know how to improve this pc, and yes, I went for the integrated vega 8. I believe that I may go with vega 11 but would that be overkill for minecraft?
*Duplicate because I included the wrong part list last time
https://linustechtips.com/topic/1360063-building-budget-pc-help/
Country: Canada
I'm not sure if you intend on putting a gpu in this but 750W is very overkill for this machine.
https://ca.pcpartpicker.com/list/JhZWkX
Here's my version, changed 750w evga gold to corsair 450 bronze and changed 970 evo to SN550
and if you want you can go with the ryzen 5 2400g with vega 11 with the money saved
Also with that case take one of the front fans and put it on the back
   Ryzen 5 5600X (@4.8Ghz) |  ASUS RTX 2060 OC (+120 Core, +1125 Memory) |  Ballistix 16GB
ASROCK B450M PRO4  WD Blue SN 550 1TB ‎‎‎‎‎‏‏‎| Crucial MX500 500GB | Barracuda 1TB
 Corsair CX450M | Corsair Spec-Delta
24 minutes ago, Podrake said:
machine
I was thinking about putting on a graphics card but I explained that I only play Minecraft every now and then. So I thought that it would be overkill and went igpu instead. Also, I believe that you can't get windows 11 with the 2400G so I didn't choose that.
sorry, I didnt mean 2400, I meant to say 3400g
https://ca.pcpartpicker.com/list/47JBCz
If you wanna get a gpu in the future and/or wanna have 6 cores them maybe go for something like this
11500 6 core, should be good enough for your minecraft and daily browsing needs whilst allowing you to upgrade to a dedicated gpu in the future and not have to swap the cpu out
Cheaped out on basically everything whilst keeping the list decent
If you dont care too much about rgb then swap the case for a matrexx 55 mesh
I suggest overclocking your igpu via intel xtu and overclocking the ram to improve the igpu performance
You should also enable multicore enhancement if not enabled already or whatever cpu boosting setting in the bios to yeet power limits and allow your cpu to run faster
