M-Flash Help finding compatable USB
Go to solution Solved by Michael5carn,
Bought some more USBs. My 3.0 Toshiba16gb and 2.0 1GB Transcend didn't work. Finally got bios update to work with a 8GB Transcend USB 2.0 stick. Motherboard lights stayed on after motherboard update bit spooky.
Mobo: MSI B550 gaming Edge Wifi
The mobo is new but never used for many months  so not working ryzen 5600x CPU, black screen atm so need M-Flash or new mobo.
Followed this guide:
Unplugged everything and have failed the bios flash with my two USBs. The red light for M-flash only blinks 7 times then stops. Moboboard never turns on. My PSU worked fine in my old build. Then I unplugged everything and cleared CMOS (reset BIOS). But M-Flash still failing for me. Any links to compatible USBs?
https://linustechtips.com/topic/1357407-m-flash-help-finding-compatable-usb/
