I have a 5600x and the base speed should be 3.7 GHz but even when idle the cpu is always running at 4.4 GHz clock speed. I checked the Windows power settings an it's set to balanced. I'm wondering if this causes any problems, such as shortening the life of the CPU. The CPU does overheat occasionally, but I blame that on the stock cooler and lack of exhaust fans. Do I need to worry about the CPU speeds or is this normal?
https://linustechtips.com/topic/1357004-cpu-constantly-in-boost-mode/
Are you actually idle, so 0 programs open literally doing nothing, or is there stuff running? If not I don't think it is strange for it to boost.
It boosting isn't really something to worry about. It overheating is. What do you mean with overheating? Is it thermal throttling or even causing hard shutdowns?
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
I think we should first look at what software you're using to get your clockspeeds, temperatures and that its thermal throttling.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
