I am currently deciding between 2 different PC Systems that I could go with, however, I am not really sure on which choice would be the better decision. I had previously ordered a PC back in May, however, it has not shipped yet which means I am able to ask for a refund before it does.
This was the original system that I had built:
Currently, on BestBuy, I have found a PC that has very similar specs to what I had ordered, only costing about $30 more. This is the PC on BestBuy:
There are some compromises that I have learned with the PC with best, as it uses a B450 motherboard(which doesn't really bother me) and that it only comes with 3000mhz of ram instead of the 3600mhz Ram I was going to install into my PC that I had built. One huge downside though was that I heard it came with a Apevia PSU which I have heard aren't one of the greatest PSU brands out there.
Would you recommend canceling my order and going for the one on BestBuy, or just sticking to what I had pieced together?
https://linustechtips.com/topic/1353086-which-pc-system-is-better/
3000MHz RAM is a huge no. CyberPower should know better to pair that with Ryzen. The only reason to get this would be if you can't get the 3070 any other way, but the RAM and PSU have to go.
The case sucks too, BTW, but that's probably the same on both builds. Your temps are going to suck with that thing, though.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
4 minutes ago, BadBoyHaloCat said:
Can you turn that weirdly formatted list into a PcPartPicker list?
PCPartPicker Part List: https://pcpartpicker.com/list/2gZ3TJ
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($299.99 @ Amazon)
CPU Cooler: NZXT Kraken X63 98.17 CFM Liquid CPU Cooler  ($109.99 @ Newegg)
Motherboard: Asus PRIME B550-PLUS ATX AM4 Motherboard  ($140.06 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($93.99 @ B&H)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($104.99 @ Lenovo)
Video Card: NVIDIA GeForce RTX 3060 Ti 8 GB Founders Edition Video Card
Case: Phanteks Eclipse P360A ATX Mid Tower Case  ($74.98 @ Newegg)
Power Supply: Enermax Revolution D.F. 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($104.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($108.78 @ Other World Computing)
Total: $1037.77
Generated by PCPartPicker 2021-07-02 21:58 EDT-0400
Here is the better formatted list. Sorry about the original.
Just now, BadBoyHaloCat said:
Why OEM Windows?
Because they're both OEM builds. Hard to tell from the image, I know, but the first build is through CyberPower.
I do plan on adding 3 more fans onto the case as I have heard that the case has very bad airflow with what it comes with. Do you think adding the 3 extra fans would help out a lot in regards to thermals?
1 minute ago, BadBoyHaloCat said:
Oh, you're not custom building the first one? I thought this was "<custom pc> vs <prebuilt>"
The first PC was built using CyberPower PC's wbesite. The custom built pc is one that will be built by CyberPower using the components of my choice.
