Budget (including currency): ~700$ (converted from bdt)
Country: Bangladesh
Games, programs or workloads that it will be used for: Programming, video editing, graphics designing etc, and some gaming when i get bored :)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): My first build, 1 monitor only, 500gb storage for now, i'll upgrade later.
Here's the amd build :
Ryzen 5 5600g        :  260$
MSI B550M PRO-VDH WIFI                                                           :  120$
Corsair Vengeance LPX 16 (2*8) GB DDR4-3200 CL16 Memory  : 88$
Samsung 870 Evo 500 GB 2.5" SSD                                              : 60$
Cooler master Masterbox Q300L mATX mini tower case                : 38$
EVGA BR 450 W 80+ Bronze ATX psu                                            : 42$
SAMSUNG LF22T350FHW 22" 1080p 75Hz IPS LED                    : 110$
        Total      : ~720$
Here's the intel build :
Core i5 11400f  2.4ghz 6 core                                                  : 170$
Asus PRIME B560M-A Micro ATX LGA1200                             : 110$
G.Skill Ripjaws V Series 16 GB (2*8) DDR4-3200 CL16          : 88$
Western Digital Blue SN550 500 GB M.2-2280 NVME SSD     : 60$
Asus GeForce GT 1030 2 GB GDDR5 Gpu                               : 100$
HEC hx210 mATX mini tower case                                            :  37$
EVGA BQ 600 W 80+ Bronze Certified Semi-modular ATX psu :  50$
Acer SB220Q bi 21.5" 1080p 75Hz                                            :  100$
        Total  :  ~715$
Any kind reply will be highly appreiated :)
https://linustechtips.com/topic/1350656-which-build-will-be-betteramdintel/
Country: Bangladesh
Games, programs or workloads that it will be used for: Programming, video editing, graphics designing etc, and some gaming when i get bored 🙂
        Total      : ~720$
        Total  :  ~715$
Any kind reply will be highly appreiated 🙂
I would recommend getting AMD if your planning to do gaming, the GT 1030 in the Intel build is going to be slightly worse than the iGPU in the Ryzen. If you do get a better GPU, then I'd recommend going with the Intel one instead considering some people have said that Intel is better for gaming.
My specs:
Acer Nitro 5 (AN515-54)
Intel Core i5-9300H
1TB HDD (WDC WD10SPZX-21Z10T0) + 128GB M.2 SSD (KINGSTON RBUSNS8154P3128GJ1)
NVIDIA GeForce GTX 1050 (3GB VRAM / 16GB shared) + Intel UHD Graphics 630 (16GB shared)
32GB Crucial CL19 DDR4 (SDRAM) 2667MHz (downclocked from 3200MHz)
1080p 60Hz 15.6in display overclocked to 75Hz
Windows 11 22H2
Old desktop computer
AMD Athlon 64 X2 5200+
2GB DDR2
NVIDIA GeForce 6150SE nForce 430 (825MB shared (planning on getting a GT 710 to replace this)
500GB HDD
Windows 7 Professional SP1
Lenovo Ideapad 310-15IKB 80TV (broken hinge)
Intel Core i5-7200U
1TB HDD
Intel HD Graphics 630 (2GB shared)
8GB DDR4 2133MHz
768p 60Hz 15.6in display
Linux Mint 20
2 minutes ago, Pixelfie said:
Yes. It's not bad, but if you can spend some extra money on a better unit I would recommend it. Maybe a Seasonic GX would be good.
thank you for the suggestion! but actually i don't understand it, pcpartpicker says 200w is enough, i have 600w 80+ bronze!
is there anything else i'm missing on psu quality?
Thank you for the suggestion! and, you mean , if i can get a better gpu in that price, i should choose intel?
Yeah, if you can get a 1050 or something, go for the Intel build instead
Otherwise, stick with AMD
My specs:
Intel Core i5-9300H
Windows 11 22H2
2GB DDR2
500GB HDD
Intel Core i5-7200U
1TB HDD
8GB DDR4 2133MHz
Linux Mint 20
It's not about how much w a PSU has, but also the quality. Here's a PSU tier list, hope it will help you.
Amd with a cheeper board and ssd
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
Oh, thank you! But why over the Intel build? 🤔
It would be cheeper than.
The Intel build is already pushed pretty hard for budget
Bios database
prior build:
Yup! Btw, can you tell me if I need to change anything in the amd build?
If I were you id get something like a B550m pro4, crucial p1 500gb, get a evga bq instead of a br, and get the cheeper monitor
Bios database
prior build:
yes! i've also though about asrock b550m pro4, but the only problem is i won't have wifi or bluetooth with it.
and for the m.2 nvme, i'm actually thinking about getting that instead of samsung sata ssd, but i'm not actually sure as i like their magician software 😅.. and i don't know about psu, i'll try to get evga bq then 🙂
48 minutes ago, Samin_556 said:
Hey, now I changed evga br with cooler master mwe 450 v2 😄
how would this one be?
I think the EVGA would probably be better. If you can find a corsair CX, get that, but otherwise this is probably the best you can get for a decent price
Samsung ssds are overpriced for their preformance. The crucial one would be a better value.
As for the board, you could get a cheep pcie adaptor, it would still be cheeper than the listed board.
Bios database
prior build:
