Power supply advice
Go to solution Solved by Guest,
2 hours ago, Redoanul Hasib said:
So bronze is the entry level and higher is better.
Only in terms of efficiency.  Nothing more.
The reason for the Cooler Master suggestion has to do with the fact that it uses an LLC topology with DC to DC for the non-primary rails and NOT efficiency.
Hi,
I got a pc from my relative. System config-
Cpu- intel i3 8100
Gpu- msi radeon rx 570 armor 8gb OC
Motherboard- gigabyte H310M H
Ram- corsair vengeance LPX 2400 8gb ddr4
Ssd- team gx2 128gb sata ssd
Hdd- Seagate barracuda 500gb 3.5 inch 7200 rpm
Psu- Antec ATOM V550
Now, im curious about the psu as pc restarts during gaming. Even though it's 550 Watt its really cheap dont know how.
Just wanted to know if the psu is good enough for the system or should i buy a new one. If so please suggest me a good budget psu. I live in Bangladesh.
https://www.startech.com.bd/component/power-supply
This is the shops link that i can buy a psu if necessary. Thanks in advance.
https://linustechtips.com/topic/1349930-power-supply-advice/
2 hours ago, jonnyGURU said:
Is the Atom the 80 PLUS Gold version with the Purple label?
Judging by 'V' it's teal label non-certified one. So even more garbage.
This one :
https://www.startech.com.bd/antec-atom-550w-power-supply
So yeah, while the PSU is garbage it's probably not PSU related issue, wouldn't hurt to replace it anyway tho and then work out the rest if restarts still happen.
This one at the very least : https://www.startech.com.bd/corsair-cv450-power-supply
Better if this one : https://www.startech.com.bd/corsair-cv650-80-plus-bronze-certified-power-supply
Even better if this one : https://www.startech.com.bd/corsair-cx550f-rgb-power-supply (or it's 650/750W version if you plan some high-end-ish upgrades)
All of them being Corsair is a total coincidence, i mean, there are CM MWE Bronze V2 and Antec Neo Eco Zen for the price of CV650 which are technically better but i'm not sure if i can recommend them, CM MWE V2 one had some problematic batches and there are almost no reviews on Antec NE Zen.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1349930-power-supply-advice/#findComment-14823679
This one :
Will the Corsair 450watt one be sufficient enough, i mean this one is 550. Dont understand 80plus though.
https://linustechtips.com/topic/1349930-power-supply-advice/#findComment-14823986
It's a little better.
This is the best deal:  https://www.startech.com.bd/cooler-master-mwe-450w-v2-power-supply
80 PLUS is just a level of efficiency.  How much AC is required to product X amount of DC.  That's all.
https://linustechtips.com/topic/1349930-power-supply-advice/#findComment-14824004
So bronze is the entry level and higher is better.I'll have to buy the cooler master one cause i have a tight budget also dont have a plan to upgrade. Thanks for the help.
https://linustechtips.com/topic/1349930-power-supply-advice/#findComment-14824263
https://linustechtips.com/topic/1349930-power-supply-advice/#findComment-14824427
