Budget (including currency): 1600 JOD
Country:  Jordan
Games, programs or workloads that it will be used for:  Android/ios mobile app development, Virtual machine ( MacOS), gaming, WoW,ESO, W3.
i have 2 60hz 1080p monitors which i'll use for now until i get a new GPU (currently rx 580 and planning on getting rx 6800 xt), when i get the new gpu i'll upgrade to 140hz 2k freesync monitor.
i'll buy a case aswell, it'll cost around 50~100jod max.
Is the SSD i chose good enough for the OS and my games ? its allot cheaper than getting a Samsung 970 or 980/pro.
am slightly worried about the watercooler, i cant find a decently cheap dual or triple fan water cooler solution and i need water cooling, since Jordan gets really hot in the summer and air cooling won't cut it.
but ye what do you guys think about my build ? is the mobo good ? i can add an extra 30~ jod and get a x570 such as the ASRock X570 PHANTOM GAMING 4 AM4 Motherboard or MSI AMD Ryzen X570 A PRO AM4 PCIe 4.0 ATX Motherboard
https://linustechtips.com/topic/1346351-help-me-build-my-pc/
Country:  Jordan
i have 2 60hz 1080p monitors which i'll use for now until i get a new GPU (currently rx 580 and planning on getting rx 6800 xt) planning to upgrade to 140hz 2k freesync monitor.
are you asking a question or telling us how to fix whatever problem you have?
i5-9400f
corsair 16gb (2x8) kit + 4x1 gb microsoft stick both 2666
asrock b350m pro4 lga 1151
intel ax-210 wifi card
msi rx 580 8gb
nzxt h510 airflow case white
650w thermaltake gold
512gb nvme
1tb wd blue
1tb seagate external
https://linustechtips.com/topic/1346351-help-me-build-my-pc/#findComment-14795632
Country:  Jordan
if youre worried about a case just dont get one (its called passive airflow btw) it will save you so much monet and time , leave the parts exposed , i see you only have one stick of ram , make it dual channel (two sticks of 16gb) and since everything else looks good , go with it.
i5-9400f
msi rx 580 8gb
512gb nvme
1tb wd blue
https://linustechtips.com/topic/1346351-help-me-build-my-pc/#findComment-14795760
Just now, zutch said:
am more worried about liquid leaking from the watercooler since am not familiar with this brand, am reading mixed reviews about it.
depends where you are ordering from (amazon im guessing) deepcool is a trusted brand i guess. i would go with this
sure some of the reviews are shitty , but i used it in a customers build
https://www.amazon.com/gp/product/B086BYYFG5/ref=ox_sc_saved_title_5?smid=ATVPDKIKX0DER&psc=1
i5-9400f
msi rx 580 8gb
512gb nvme
1tb wd blue
https://linustechtips.com/topic/1346351-help-me-build-my-pc/#findComment-14795771
12 minutes ago, zutch said:
wouldn't i be better off with triple cooling ?
it only the size of the radiator , your only cooling the cpu with it , you rlly only neet 120mm of radiator for a single cpu. 🙂
i5-9400f
msi rx 580 8gb
512gb nvme
1tb wd blue
https://linustechtips.com/topic/1346351-help-me-build-my-pc/#findComment-14795795
7 minutes ago, zutch said:
alright, what about the mobo choice ? should i put in the extra money to get one of the 2 x570 mobos i mentioned?
the b550 is good enough , i think it has two or more ram slots , you can fit two sticks of ram in , just stick with the mobo you have listed.
i5-9400f
msi rx 580 8gb
512gb nvme
1tb wd blue
https://linustechtips.com/topic/1346351-help-me-build-my-pc/#findComment-14795825
