No, you don't need a capture card for video recording. As for dual monitors, just use a different port on your GPU for each one and you'll be fine.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1345558-gpu-and-capture-card/#findComment-14789507
Does it matter what other specs it has for it to be able to record? My current computer doesn't record very well. It was only $350 so I'm not sure if that's the reason.
https://linustechtips.com/topic/1345558-gpu-and-capture-card/#findComment-14789531
Yes, it does matter. What are the specs of your new rig?
SPECS:
https://linustechtips.com/topic/1345558-gpu-and-capture-card/#findComment-14789536
29 minutes ago, AvocadoDude1 said:
Yes, that system will do just fine especially if you use nvenc encoding on your GPU. But I would consider making a new thread here and having people check it over as there might be some other improvements to be made.
SPECS:
https://linustechtips.com/topic/1345558-gpu-and-capture-card/#findComment-14789603
