I recently upgraded from 16GB to 32GB of RAM by adding two more sticks (yes, exact same model number). Prior to this, I was able to run my PC fine with XMP pushing the RAM from 2330 to 3200MHz. After installing the new RAM, however, I cannot do this without my PC crashing after some time.
Specs:
Asrock B550 motherboard
Ryzen 3700X
G.skills Ripjaws 4x8GB RAM
GTX 970
EVGA 650W PSU
https://linustechtips.com/topic/1343963-pc-crashes-running-xmp/
Specs:
Ryzen 3700X
GTX 970
EVGA 650W PSU
disable it when you dont need it , only when your playing games , and get a ram fan from amazon , they are only like 80-200 usd
i5-9400f
corsair 16gb (2x8) kit + 4x1 gb microsoft stick both 2666
asrock b350m pro4 lga 1151
intel ax-210 wifi card
msi rx 580 8gb
nzxt h510 airflow case white
650w thermaltake gold
512gb nvme
1tb wd blue
1tb seagate external
https://linustechtips.com/topic/1343963-pc-crashes-running-xmp/#findComment-14777122
More RAM being overclocked is going to put more load on the memory controller in the CPU and potentially other components, unfortunately XMP isn't guaranteed and tends to be a pain in the ass. You can try to stabilize it by incrementally increasing the SoC voltage a little bit more to see if it gets more stable, without pushing it too far.
System Specs: (Click Expand)
          "Beatrix"
  • CPU AMD Ryzen 7 5800x3D
  • Motherboard GIGABYTE X570 I AORUS Pro Wi-Fi
  • RAM 2 x 16GB Corsair Vengeance RGB Pro @ 3200mhz CL16
  • GPU Gigabyte Eagle RX 6700XT
  • Case Corsair Crystal 280x
  • Storage 1x Samsung 980 Pro (1TB) 1x Samsung 970 Evo Plus (500GB) 1x Samsung 860 Evo (1TB)
  • PSU EVGA G5 850W
  • Display(s) 32" Odyssey Neo G7 & 27" Viewsonic XG2705
  • Cooling Corsair H100i Elite Capellix AIO | 4x QL120 RGB fans | 2x QL140 RGB fans
  • Keyboard Logitech G Pro
  • Mouse Logitech G502 Lightspeed /w Powerplay
  • Sound Logitech G Pro Wired
  • Operating System Windows 11 Professional 23H2
https://linustechtips.com/topic/1343963-pc-crashes-running-xmp/#findComment-14777127
Specs:
Ryzen 3700X
GTX 970
EVGA 650W PSU
From my experience some RAM on AMD platforms dont like to run at their full frequency. my suggestion would be to manually ramp up the frequency until it becomes unstable. Personally I was only able to get my 3200Mhz to 2933 due to my motherboard. This is actually more common than you think
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/1343963-pc-crashes-running-xmp/#findComment-14777133
