Budget (including currency): £900
Country: UK
Games, programs or workloads that it will be used for: not sure
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): MSI B550 WiFi Edge, Corsair H150i 360mm
Hi, I'm looking for a case that would support the radiator that I've purchased. Basically I'm looking to do my first build in quite a few years and am buying parts on 'firesales' or when they're discounted. I would have liked to buy a smaller cooler but the one above was £68 and was £100 off and was cheaper than a smaller alternative.
I was looking at a 220t case but I've told I will cause problems as the tubes will be higher than the CPU block?
Any advice on a nice RGB case so I can shop around and and find a deal?
Thanks
https://linustechtips.com/topic/1342952-first-build-aio-advice/
Country: UK
Thanks
https://uk.pcpartpicker.com/product/pvdrxr/cooler-master-masterbox-td500-mesh-w-controller-atx-mid-tower-case-mcb-d500d-kgnn-s01
https://uk.pcpartpicker.com/product/d82bt6/lian-li-lancool-ii-mesh-atx-mid-tower-case-lancool-ii-mesh-rgb-black
both are good and a 360mm aio will fit
https://linustechtips.com/topic/1342952-first-build-aio-advice/#findComment-14769561
15 minutes ago, Omar.B said:
Thanks. Would the pipes be at the bottom or top? I've been told that's what causes problems?
https://linustechtips.com/topic/1342952-first-build-aio-advice/#findComment-14769571
