I assume you mean 4 fans on 1 header & yes, they won't go fast and may even struggle to actually start moving due to such low voltage. They may just tick, which is them moving  tiny bit then going back
Ryzen 5 1500x, Noctua NH-L9x65 SE-AM4, GA-AB350N, 16GB 1600Mhz, EVGA GTX 970, 250GB Samsung 960 Evo, 120GB Samsung 840 Evo, 1TB WD Green & 2TB Seagate Barracuda. 650w OCZ ZX & Cooler Master Elite 130. Acer CB241HQK 4K, LG IPS234V-PN 1080p, Ducky Zero Shine All Blue/Anne Pro Brown/SteelSeries Apex Pro & Razer Naga 2014
https://linustechtips.com/topic/13424-help-with-fan-headers/#findComment-144388
You can buy PWM 4 Pin Y Splitter cables (2 CPU 4 Pin Fan Connectors) and they work perfectly fine with most fans
i7 930 @ 4.2Ghz | Gigabyte X58A-UD7 | Seagate ST2000DX001 SSHD 2TB | WD5000AAKX 500GB | Samsung SH-B083A Bluray Drive | Gigabyte GTX 670 2GB GV-N670OC-2GD | Corsair 12GB 1600Mhz CMZ12GX3M3A1600C9 | Corsair H50 in Push Pull | SeaSonic X750 | CM 690 II Advanced | Windows 7 Ultimate x64 | HP 2159M 1080p | Asus ProArt PA238Q 23" 1080p IPS Monitor | Asus VS239H IPS 1080p (Portrait) | Razer BlackWidow Expert MX Blue (2011) | Razer Lachesis 5600
https://linustechtips.com/topic/13424-help-with-fan-headers/#findComment-144439
