Fan hub
Go to solution Solved by coredrakoz,
7 minutes ago, wONKEyeYEs said:
They will accept 3 or 4 pin fans as long as your MB has 4 pin headers which it will if remotely recent.
I dont find the same for europe 😕
This will work?
https://www.amazon.es/Netspower-Computadora-Ventilador-Adaptador-computadora/dp/B085C2XMQR/ref=mp_s_a_1_6?dchild=1&keywords=fan+splitter&qid=1622140933&sr=8-6
1 minute ago, wONKEyeYEs said:
So if you have two fan headers free besides the CPU fan header then you can put 3 fans on each header for 6 total.
https://www.amazon.ca/ThreeBulls-Splitter-Computer-Extension-Converter/dp/B07MXNT6V4/ref=sr_1_7?dchild=1&keywords=fan+splitter&qid=1622140562&sr=8-7
Those are all 4 pin?
https://linustechtips.com/topic/1342232-fan-hub/#findComment-14764363
This will work?
https://linustechtips.com/topic/1342232-fan-hub/#findComment-14764385
2 minutes ago, wONKEyeYEs said:
Any splitter will do.
You could chain two 2 way splitters for 3 fans.
Or something like this, but I would check your amperages before populating all 4.
MB fan headers are typically good for 1Amp.
Many fans are only 0.16 amps so four would only be 0.64Amps which would be safe.
But four 0.25Amp would be 1Amp and might be too much as the fans do surge a little upon startup.
https://www.amazon.ca/Bewinner-Computer-Splitter-Connector-Adapter/dp/B07MTFF1M7/ref=sr_1_13?dchild=1&keywords=fan+splitter&qid=1622140920&sr=8-13
I think im doing 2 of 3 , one per head i think its fine the one i posted i think will work fine with what u told me
Edited by coredrakoz
fail
https://linustechtips.com/topic/1342232-fan-hub/#findComment-14764410
