Concerning high temps.
16 hours ago, Br1t1shB33f said:Ambient room temp is about 20-25c, the two front fans are not stock bought them separately. The front of the case sits on the edge of the desk to allow fresh unheated air to be drawn into the case and the rear exhaust has the space of the whole desk 120cm to blow away. Case only allows 1x120mm exhaust.
Everything seems pretty good from your end tbh. Also considering the temps you mentioned are sustained on maximum load, there shouldn't be any degradation per se. You can always opt in for a good thermal paste to find a difference; but considering you've just had a week, I'll suggest to wait.
If after a few months you find the temps rocketing, it'll probably because the stock paste was no good and you opt in for a swap then.
As of now, let it be.
