Keyboard problem
Go to solution Solved by kelvinhall05,
6 minutes ago, Jimvar said:
Has this been a problem to other people too? I find it bizarre that a whole row on the keyboard would break, while the others work fine. Maybe it's a driver/windows error? Haven't messed around in Synapse will keys so that is off the table.
It is a faulty row in the keyboard matrix. Likely an easy fix if you have soldering experience but it would be stupid to do on a brand-new product that is under warranty. Just return it.
Return it, it's faulty.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1336814-keyboard-problem/#findComment-14722977
https://linustechtips.com/topic/1336814-keyboard-problem/#findComment-14722982
SPECS:
https://linustechtips.com/topic/1336814-keyboard-problem/#findComment-14723000
Aah alright then, I thought having a full row broken would have been driver fault. Thanks for the help!
https://linustechtips.com/topic/1336814-keyboard-problem/#findComment-14723003
