Red VGA light
3 minutes ago, Heizeris said:My psu is Aerocool pgs lux 850w
As shown by the tier list, your PSU is Tier D.
It will work, but not well.
Here's my guess as to what happened.
When you were playing your game, something in your PSU gave out. I don't know what. In any case, it's not able to provide something that the motherboard needs.
Based on what you've told me, it sounds like the 12V rail. The CPU and GPU need the 12V power from your PSU to run, and what you said (staying on red CPU light for 5 seconds then switching to the VGA light and staying) sounds like a fault with your PSU.
IF your 1050 Ti works in your friend's PC, get a new power supply. Get a Tier A or B 550W unit from this list.
IF your 1050 Ti does not work in your friend's PC, ask him if you can borrow his PSU to test. If your random GPU card works then, you know that the PSU was the problem, but it also killed your 1050 Ti (which sucks).
