Budget (including currency): 1250 USD including monitor, try to lower it
Country: Czech Republic
Games, programs or workloads that it will be used for: Light gaming - Minecraft (propably shaders), Fortnite; Video editing - DaVinci Resolve; Occasionally 3D - Fusion 360, Blender
Other details
Hello, I'm trying to build my first resasonable quite cheap system. I think that the processor and GPU are the best for my budget but I'm not too sure about the rest. Also there was some warning about possible incompatibility of the motherboard and Zen 2 but in the reviews on pcpartpicker someone said that with this processor it was ok. Also please tell me if there will be any bottleneck.
Thanks in advance
https://linustechtips.com/topic/1333313-help-with-new-pc/
If youre shopping in Europe, use Europe PC Part Picker's listing (Germany is my favorite on my pick as its pretty much mecca of PC parts in europe imo) as it reflects your pricing better.
You can go for an 11400F and a B560 motherboard and get a way better performance than a 3600, hell you can get away with the last gen 10400F and a B460 motherboard to get similar performance if your country doesnt have rocket lakes yet. Or you can wait for 5600X prices to drop.
B450 with the Ryzen 3000 Ready moniker on retail usually already come updated with the bios to let you boot in. But if you cant boot, its simple solving of either ordering Boot Kits off AMD website to flash your BIOS or flash it over USB if your board is able to do that.
Bottlenecks arent that scary, but to answer your question: no.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1333313-help-with-new-pc/#findComment-14697558
