Budget (including currency): £1000
Country: uk
Games, programs or workloads that it will be used for: going to be used for gaming playng (ark suvival evolved, rust, cod warzone, satisfactory)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): have perpherals montoitor 120hz 1920x1080 upgrading from a i5 7th gen 16gb ddr4 2666mhz 1070 corsair 550w antec p8
only upgrading cpu motherbaord and gpu for now
my upgrades
https://linustechtips.com/topic/1332962-doing-upgrades-looking-for-help/
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
7 minutes ago, SorryClaire said:
Where did you find rtx3070 for 360 quid? otherwise it looks good
