Budget (including currency):  1000 USD
Country: USA
Games, programs or workloads that it will be used for: VR, Blender,COD Warzone, Rocket League
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  Need advice if I should change anything , gpu is going to be rtx 2060.Screenshot_20210428-160605.png.4b8acb0969c9b709f11b3284cb86aa4d.png
https://linustechtips.com/topic/1332879-pc-building-advice/
Country: USA
finding the amd ryzen 5 3600 at that price point isn't gonna happen
my signiture was cool, but its a lie now
https://linustechtips.com/topic/1332879-pc-building-advice/#findComment-14694459
Adorama has it on backorder for $210, and there's other stores where you can get it now for $250. Not quite the $200, but not that far off.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1332879-pc-building-advice/#findComment-14694468
really, the lowest i can find them is for $250, thats good to know
https://linustechtips.com/topic/1332879-pc-building-advice/#findComment-14694469
