I have a question. I built my first PC last night and the motherboard rgb (which is the only rgb in the whole computer) turns on when I plug it in and flip the switch to on. However, there is no other indication that it has power, no fans spinning, no indicator light on motherboard, no display output. I also noticed that if I plug a keyboard in, it doesn't have power either. Windows has not been installed yet. What did I do wrong?
Specs:
Motherboard: Asrock B460 Steel legend
CPU: Intel Core i5-10400f
Graphics card: Zotac Gaming Geforce GTX 1660 6GB
Please tell me if you need more information, All parts are brand new from amazon or newegg.
https://linustechtips.com/topic/1332497-my-first-pc-build-doesnt-work-please-help/
1 minute ago, burnttaco said:
If you have any other computers put the power supply in the other PC and see if that works. Also is the power supply spinning?
I don't have another PC to test it on. the fan is not spinning, but it could just be in a low power mode.
