building my pc
Go to solution Solved by dean_5234,
3 minutes ago, jacobi_nolini said:
i was able to get my hands on an ASUS Republic of Gamers Strix GeForce RTX 3070 White Edition Graphics Card. i couldn't find any white liquid coolers from name brands aside from this one
oh nice gpu
you could go for the deepcool castle 360 white
https://www.amazon.com/Addressable-Anti-Leak-Technology-Controller-Motherboard/dp/B07X74W9TL/ref=sr_1_4?dchild=1&keywords=white+aio&qid=1619207527&sr=8-4
Budget (including currency): ~$2400 USD
Country: united states
Games, programs or workloads that it will be used for: warzone, cold war, cs go, minecraft, apex,fortnite, rainbow six
https://linustechtips.com/topic/1330563-building-my-pc/
list is blank
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1330563-building-my-pc/#findComment-14677126
overpriced cooler
do u have a gpu or r u gonna run of igpu for now
Big nerd.
https://linustechtips.com/topic/1330563-building-my-pc/#findComment-14677142
Just now, davemc said:
overpriced cooler
https://linustechtips.com/topic/1330563-building-my-pc/#findComment-14677145
oh nice gpu
Big nerd.
https://linustechtips.com/topic/1330563-building-my-pc/#findComment-14677182
1 minute ago, davemc said:
would there be any compatibility issues with the radiator or any other components i have? thank you for the recommendation, i will definitely switch that out.
https://linustechtips.com/topic/1330563-building-my-pc/#findComment-14677188
It fits in the top of your case. Everything you listed is compatible.
https://linustechtips.com/topic/1330563-building-my-pc/#findComment-14677195
