Hey forums,
I wanted to know if anyone has had experience, success, or even insight on using two USB bluetooth adapters on the same system. What I would like to do is use one with the standard broadcom drivers for headset, keyboard, and other miscellaneous things, and another as a dedicated Motioninjoy PS3-controller adapter. The issue here is more with the drivers, since motioninjoy installs new drivers for the bluetooth adapter that can't be used with anything aside from PS3 controllers.
Basically, I want one dongle to operate using one set of drivers and the other with a different set. Is this possible?
Thanks for any insight into the matter.
