7 minutes ago, GreenAries.22 said:
I have a Inspiron 5558 i3 it works fine I just want it to run more like a new laptop. Is it able to be upgraded and is it even worth it?
storage ram internet https://laptopmedia.com/highlights/inside-dell-inspiron-5558-15-5000-disassembly-internal-photos-and-upgrade-options/   research the price and see if tht is worth it
https://linustechtips.com/topic/1329909-laptop-upgrade-help/#findComment-14671824
"more like a new laptop" in what? Boot times? Usability in multitask? Ability to run games?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1329909-laptop-upgrade-help/#findComment-14671826
10 minutes ago, GreenAries.22 said:
ability to run games smoothly
Thats wishful thinking, especially if we talking running newer games. In that case, build a new system or buy a new gaming laptop. But i think esports title can do fine with RAM upgrade so the igpu can have more vram.
But for the former, you can boost boot times with upgrading to an SSD.
https://linustechtips.com/topic/1329909-laptop-upgrade-help/#findComment-14672986
Thank you
https://linustechtips.com/topic/1329909-laptop-upgrade-help/#findComment-14673754
