Hi Everyone,
First of all sorry if this has been answered but I wanted to get some clarification on my specific build, so thanks in advance.
Just out of curiosity, are the temperatures below fine or I should be worried? I read that as long as the temps under load are close to 70 and normal use is around 40 it is fine but just wanted to make sure asking you fine people on this forum.
Specs:
Ryzen 5 3600
Cooler CPU Cooler Master MasterLiquid ML240L V2 RGB
GIGABYTE B550 AORUS ELITE V2
Corsair Vengeance RGB Pro 16 BG DDR4 3200 Mhz, CL16
SSD TeamGroup MP33 PRO 1TB, PCIe Gen3 x4, M.2
KFA2 RTX 3070 Dual Fans (Only one I could find)
Fractal Design Meshify C
Corsair TX Series TX650M, 650W
The AIO is on the front as intake in front of the radiator, case has mesh cover (didn't fit on the top but read that it is fine like this too)
Two fans are on the top of the case as exhaust and also one on the back as exhaust
These are the photos showing the temps:
Full load with heaven and CPU-Z stress test at the same time, no OC on the GPU
Idle:
https://linustechtips.com/topic/1329538-temperature-related-question/
