D5 Pump too weak?
Go to solution Solved by Guest,
It's fine.
I ran a similar setup with no issues.
Hi everyone!
No matter how much I google this, I'm not finding any answers to my question, so i hope, you could help me out here.
Short question: Will a D5 Pump (EK-Quantum Kinetic TBE 200 D5 PWM) handle 3x 360 Radiators with 2x Watercooled RTX 3090s (including backplate cooling) and a Threadripper 3960X?
Long question:
I'm planning a custom loop for my gaming and rendering PC upgrade, because I'll run all GPUs and the CPU under heavy load basically 24/7 (more on that later). I though I'll need as much cooling as I can cramp into my new Lian Li O11D XL (more is more, right?).
Also, I sit next to it, so silence would be highly appreciated.
I've ordered a lot of EK stuff like a
  • EK-Quantum Kinetic TBE 200 D5 PWM
  • 2x EK-CoolStream PE 360 Radiators
  • 1x EK-CoolStream SE 360 (Slim Triple) Radiator
  • 2x Vector GPU cooling and i preordered 2x active backplate cooling.
  • 1x EK-Quantum Velocity sTR4
I fear, that it is too much to handle for a single D5 Pump. Do you have an advice for a water cooling noob like me?
About the 24/7 run (in case you're wondering):
I'm a software developer, CG artist, photo/videographer and gamer. My GPUs are basically rendering all the time either in cooperation with the CPU, or the CPU is busy handling a lot of VMs and microservices.
Thank you a lot for any information regarding this topic!
https://linustechtips.com/topic/1329179-d5-pump-too-weak/
45 minutes ago, messmaster said:
Thanks man! Appreciate it! Nice build log by the way! One more follow up question since you got a similar build: are two liters of fluid enough?
It was just baaaaaarely enough for me. I topped off with a tiny bit of distilled water for aesthetics reasons. Depends on how big of a reservoir you use.
(Make sure you use the quote function so that when you're replying to someone, they get a notification.)
https://linustechtips.com/topic/1329179-d5-pump-too-weak/#findComment-14666084
Wow, thank you again! It would be a nightmare to complete the build and have not enough liquid to fill it 🙂 just ordered another bottle just to make sure 😉 Thanks alot!
https://linustechtips.com/topic/1329179-d5-pump-too-weak/#findComment-14666463
