1 minute ago, JuicyLeaf said:
I recently just purchased a new pc case (cheap off brand one), it came with 4 fans and all of them are connected to a hub on the back of the case. The hub, however is powered via Molex, which my power supply does not have.
Maybe you could get a sata to molex converter? If you don't want to go that route, you could get a new hub.
https://linustechtips.com/topic/1328467-help-with-fans/#findComment-14660627
