I am currently doing a build in the hadron air and I was wondering what cooler I should get on my GTX 700 2gb. The blower style from PNY or ACX cooler from EVGA. The reason is because there is only about a half an inch between the graphics car and the psu and I wanted to know what would be the best for cooling.
https://linustechtips.com/topic/132745-blower-style-graphics-card/
The ACX would be the best, normally aftermarket non-referance coolers are much better than stock cooler on the GPU's, so an ACX for sure :)
Plus it's EVGA, great customer support, great warranties
This is NOT true. With the limited airflow in the Hadron, EVGA recommends a blower cooler. Owners of ACX cards report seeing up to 10 degrees HIGHER temperatures than people with blower style coolers.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0CEoQFjAD&url=http%3A%2F%2Fwww.overclock.net%2Fa%2Fevga-hadron-air-chassis-tips-compatibility-guide&ei=zXI1U7u8HaPmsASX0YHwDA&usg=AFQjCNGGDpSWHKytk5lH7Oy3ZbMcr7VD4Q&sig2=sdUKVrIy5DA4mZnbjFh5UA&bvm=bv.63808443,d.cWc
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
What about the triple fan from pny? it seems to be a lot cheaper
Amazon
here is my amazon link I don't know if it's the blower or triple fan style.
Oh my bad, didn't see that OP mentioned that he was using a Hadron. I don't know much about the Hadron, but if EVGA actually recommends a blower cooler, then go for it OP :)
Any recommendations for a blower style 770?
I saw a MSI one that is around 320 whereas the stock is 390
In your case 100% use a blower, I'd pick EVGA myself because in my country they are No1 for warranty, and MSI have very slow RMA service here unless it's a return to base warranty from the retailer.
I know EVGA sell them with either the plastic or metal Titan style cooler.
