Budget (including currency): around 1300-1400 usd
Country: USA
Games, programs or workloads that it will be used for: mainly Minecraft, media consumption, light editing, might try streaming if possible, and school work
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc.):
This will be my first build, I want something that looks good and that will run Minecraft well lol. If you all have any recommendations or have any feed back on whether ill possibly be able to stream Minecraft and maybe some rocket league at 1080p with the set up please let me know.
CPU: AMD RYZEN 5 3600
GPU:EVGA GTX 1650 Super (I already bought this card, locally and was the best bang for the buck i could get now due to the GPU insane prices)
PSU: NZXT 650
AIO: NZXT X63 rgb
MOTHERBOARD: ASUS R-OG STRIX B450 F
CASE: NZXT H510 ELITE
RAM: CORSAIR VENGANCE RGB 16gb RGB (WHITE)
SSD XPG S40 RGB 512gb
SSD Sandisk SSD Plus 1tb 2.5"
https://linustechtips.com/topic/1324432-help-im-trying/
Hi there. This seems like a good build and I love your choice with NZXT! However for the price range you have I suggest you drop the NZXT X63 for a different cooler and if you are able to get it at retail price, a 3060ti and possibly upgrade your CPU too, however it doesn't seem that would be too necessary as it does come with the 6 cores and 12 threads. However I would advise if you don't plan on doing any over clocking as well you might want to take a quick look at the Ryzen 5 2600. Sorry as my accuracy on the CPU may be a bit off as I am a fan on intel. Good luck!
https://linustechtips.com/topic/1324432-help-im-trying/#findComment-14632188
