Need help upgrading my PC storage
31 minutes ago, Skadeshot said:I'm upgrading the storage now to a 970 Evo 250gb m.2 SSD
I think this SSD is a bit overpriced. In my local market I can get a 500GB NVMe, like a Crucial P1 or Kingston A2000, for the same price
QuoteWhat would happen if I leave my old drives in the system, will they be able to be accessed even though the old SSD isn't the
boot drive anymore? Will the old 1tb HDD still work with the new storage so I don't need to turn it into external drives?
Youd have to make sure that the first boot option in BIOS is your new SSD.
The files will still be accessable if you have not locked it with some sort of encryption.
The old HDD will still work, as long the you dont plan to use installed programs from the drive, since those will most likely depend on Registry entries that dont exist on the new installation of Windows.
You can leave everything connected inside your PC, just make sure you install Windows onto the correct drive and set the correct boot order in BIOS
