Budget (including currency): $800 CAD
Country: Canada
Games, programs or workloads that it will be used for: CS:GO, Rainbow 6 Siege, Valorant and Apex Legends (if possible).
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I'm currently using a cheap laptop. I plan on buying about 2-3 months from now. I just need some help putting a PC part list that can run the games above at 100+ Frames per second. I hope this isn't too much to ask for.  Playing Apex Legends is give or take however it would be nice to be able to run it. Thanks in advance for any help.
https://linustechtips.com/topic/1323352-need-help-planning-out-a-pc/
Country: Canada
That will be hard for $800CAD Which is $600 USD
5 minutes ago, trillj77 said:
Would it be doable at a budget of $1000 CAD?
https://pcpartpicker.com/list/
Don't mind that its 1.5k the Gtx 1660 will drop down to like $200 once the pandemic is over.
Which will make the price like $900 USD idk how much that is in CAD
Can you help me make a parts list?
Do you want me to create a parts list which you can use until your graphics card comes? It probably will not do 100 fps without the graphics card, but atleast it is quick for other tasks until they come in stock.
Yeah that'll work great. I can get a GPU once the prices drop a bit lower.
PCPartPicker Part List: https://ca.pcpartpicker.com/list/8KqQ2V
CPU: Intel Core i5-10400 2.9 GHz 6-Core Processor  ($208.25 @ shopRBC)
Motherboard: MSI B460M PRO-VDH WIFI Micro ATX LGA1200 Motherboard  ($139.99 @ Newegg Canada)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($99.99 @ Newegg Canada)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($67.99 @ Newegg Canada)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($75.30 @ Amazon Canada)
Power Supply: Corsair CXM 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($89.99 @ Best Buy Canada)
Total: $681.51
Generated by PCPartPicker 2021-04-07 16:32 EDT-0400
This one is pushing your budget a bit (i.e total cost may be closer to around 900 CAD w/graphics card) but it is a pretty good bang for buck system.
Total: $681.51
Thanks a ton man. Have great rest of your day.
