11 minutes ago, Tolan36 said:
My case has a usb 3.2 and my motherboard only has a plug for a 3.0 what do I do?
Adapter?
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1322873-need-help/#findComment-14621280
14 minutes ago, Tolan36 said:
I’ve tried finding one but I can’t for the life of me this is my first build and I just installed my motherboard in the case and the aio cooler
https://www.amazon.com/JoyReken-Internal-19-Pin-Header-Adapter/dp/B08KHVN3RQ/ref=sr_1_4?dchild=1&keywords=3.2+to+3.0&qid=1617768886&sr=8-4
Also, you dont need it to boot up the pc, just the port wont work
Big nerd.
https://linustechtips.com/topic/1322873-need-help/#findComment-14621307
