Earlier today I was trying to get some dirt out of a standard usb a port and I had to stick a small toothpick in there to get it out. In doing so, I had to slightly nudge/bend the receptacle (the inner rectangle) a little bit. It looks fine but I'm worried it might be a little out of shape or messed up. Should I be concerned or is the port durable enough for that? Thanks.
https://linustechtips.com/topic/1318349-is-usb-receiver-fine/
