No, there are several circuits inside both the laptop and battery itself that will prevent it from charging beyond what it considers 100%.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1317822-laptop-battery/#findComment-14581212
That said, you will shorten the life of the battery by using the laptop while plugged in. So, if you can I would avoid using the laptop while plugged in. I understand that this is not always possible.
https://linustechtips.com/topic/1317822-laptop-battery/#findComment-14581256
That is kind of a myth with more modern systems, or at least the problem is greatly exhaggerated. I wouldn't worry too much about it.
SPECS:
https://linustechtips.com/topic/1317822-laptop-battery/#findComment-14581264
