Heya, everybody.
Long story short, The cooling in the case feels somewhat subpar right now. I'm using an NZXT H510i case right now and due to the THICC (yes, I said it) motherboard I'm using, I can no longer fit a fan on the top vent, which has left me in a 1 front/1 rear fan combination right now.
Long story short, I'd like some suggestions for decent quality RGB fans so I can turn this pupper into a decently cooled unicorn rave. Budget is roughly 120 USD and I was thinking of replacing the current 120mm fans in the case with 2 140mm fans up front and 1 120mm fan in the back. I'm about as dense as a brick when it comes to efficient cooling, so feel free to chime in and tell me if that layout would mess up the airflow in the case.
Thanks again!
https://linustechtips.com/topic/1316669-need-suggestions-for-case-cooling/
3 minutes ago, Lyri said:
Heya, everybody.
Thanks again!
I may be wrong, but it looks like your front fan is pushing and your rear fan is pushing. Use your front fan as intake and look at temperatures again.
For good RGB fans, I always like Corsair. The LL120 fans come in a pack and the iCue software is lovely. Make sure the fans are also in pull in front and push in the rear so you don't starve your parts from fresh air.
Yeah looks like it.
Turn the fan around for now, and maybe replace the fans later with a 3 pack of LL120 (One in the back, 2 in the Front)
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11 + 10)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X + native 12VHPWR-Cable
Lian Li O11 Vision
Alienware 360 HZ QD-OLED AW2725DF, MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight 2
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 Pro - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 4x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot, Testing-VMs + TrueNAS L2ARC), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 2x 360GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 2x 240GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
Rear fan is pulling and front fan is pushing, already checked. Had the same feeling at first when assembling, but I verified that. I was thinking of going with NZXT Aer 2 RGB's so I could sync them up with the case and because it seems like they displace more air than the iCue's, other than that I was definitely eyeballing the Corsairs, especially granted that they are cheaper.
Is it pushing to the front or pulling from the front?
Front fan is pushing cold air into the case and the rear fan is pulling the hot air out. I may have my terms mixed up, but that is the general setup right now. The general problem is that my motherboard has 2 CPU 8 pins and one of them is now blocking the top vent, there's not much real estate for the front fans to be pulling air into the case, hence why I was thinking of doubling down on two 140mm fans up front.
Then it's clear 🙂
But still as suggested earlier and also by @Noah0302, the Corsair LL120 will suit your needs well.
1 minute ago, Naijin said:
Then it's clear 🙂
I really am eyeing those Corsairs, honestly. Just wondering whether they'll work with the NZXT together. I reckon I'll just have to get seperate software for them?
Also, rather stupid question, but wont this sort of a fan setup accelerate the dust buildup in case? Not a big problem, I tend to clean my case every 2 to 4 weeks, anyhow. Just curious.
More intake and airflow will always bring in more dust. I don't think the H510i has a seperate dust filter in front of the fans, but it has fairly restricted airflow for sure and more fans will help. If you already clean your case often, there's nothing to worry about. Just make sure the vents stay open 🙂
The LL120 fans in the 3-pack come with a hub with an internal USB header, so then you can control the fans via Corsair iCue software.
Big thanks, bud! Looks like I may just swing that way. Haven't had too many pleasant memories with Corsair in the past, but I think I'll swing that way this time.
An other option would be the Lian Li Uni 120 3-pack which also includes a controller, but they are very rare right now so finding them will be hard 🙂
Lian Li 3 pack is actually in stock here, half the price of Corsair 3 pack or NZXT packs. 68 USD.
