The 10700K does have an iGPU, and as long as your PSU has enough PCIe power connectors for your GPU and your case fits it, you can slot it in, install the drivers, and you'll be fine.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1316464-please-help-d/#findComment-14571134
2 minutes ago, Almighty Potato said:
Ok thx, what do you mean by drivers?
He is just saying when the time comes for you to buy a dedicated graphics card, you can make sure it fits and has cables and install drivers.
until then you are fine plugging directly into mobo though
https://linustechtips.com/topic/1316464-please-help-d/#findComment-14571142
If you get an AMD GPU, you can download the drivers for your card from here:
https://www.amd.com/en/support
Just select your card via the flowchart-like thing and download the drivers it gives you.
If you get an NVidia GPU, you can download the drivers for your card from here:
https://www.nvidia.com/Download/index.aspx
Same process as before - select your card family (Titan, GeForce, Quadro), then card generation (600-series, 900-series, 2000-series, etc.), then your exact card model (GTX 650 Ti BOOST, GTX 1060 6GB, RTX 2070 Super, etc.) and select Download.
It will pull up the driver for your card, you download it, and run the program.
https://linustechtips.com/topic/1316464-please-help-d/#findComment-14571149
Thx so much
https://linustechtips.com/topic/1316464-please-help-d/#findComment-14571156
