Posted March 12, 2021 CPU: i5 6600K OC 4.4 1.3 core voltage (stock was 3.5) Mobo: MSI Z270 gaming plus (Note: pins were bent in maitenance, managed to bent back in place) GPU: MSI GTX 1060 6GB Gaming X RAM: Ripjaws V 2666MHz (XMP profiles enabled) So I get 100% usage while playing VALORANT, which makes my discord lag and I can't talk or hear ppl while lagging. I suspect my GPU is bottlenecking my CPU. But I can't think of anything more. And I know VAL uses so much cpu, but if there's any way around it any help is welcome. If anyone could help please, I'll provide more info in requested. Link to comment https://linustechtips.com/topic/1314679-i-need-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Opposite situation... CPU is bottlenecking the GPU. Check the GPU utilization percentage to confirm. Provided you're SURE the damage to the pins was fixed correctly, you can try increasing graphics settings a little to shift more workload to the GPU and see if that helps. It's counter-intuitive, but sometimes can work. Can you verify with Task Manager that the game is what's using 100 percent CPU and not some other background applicaiton/process? EDIT: I now realize you didn't expressly say the 100 percent usage was CPU, but I assumed based on the rest of your post. Please confirm if that's the case. Be sure to QUOTE or TAG me in your reply so I see it! CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15 Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14555930 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Author Even if I tweak the video settings is the same. https://prnt.sc/10jyiv7 Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14555977 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Author Plus upping vid settings means less fps than I already have Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14555980 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 9 minutes ago, Viciouszzz said: Even if I tweak the video settings is the same. https://prnt.sc/10jyiv7 Yeah, that's a clear CPU bottleneck. 8 minutes ago, Viciouszzz said: Plus upping vid settings means less fps than I already have In severe CPU bottlenecks where the GPU is being really under-utilized (such as your case of only 45 percent GPU usage) there are some instances where the FPS will increase by moving more of the workload to the GPU via higher graphics settings. That's why I suggested it, but Valorant may not be a game where this makes a difference. Be sure to QUOTE or TAG me in your reply so I see it! CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15 Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556011 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Author 1 minute ago, RAS_3885 said: Yeah, that's a clear CPU bottleneck. In severe CPU bottlenecks where the GPU is being really under-utilized (such as your case of only 45 percent GPU usage) there are some instances where the FPS will increase by moving more of the workload to the GPU via higher graphics settings. That's why I suggested it, but Valorant may not be a game where this makes a difference. Ah that sucks, any ideas on what to do? Ty for your time up until now! Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556019 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Author And basically change CPUs or? Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556020 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 7 minutes ago, Viciouszzz said: And basically change CPUs or? What FPS are you getting? What resolution are you running? Check this out. Suggests trying to limit FPS or turn on v-sync. Be sure to QUOTE or TAG me in your reply so I see it! CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15 Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556037 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Author Around 250 drops to 110 in sometimes 16:9 1920x1080 Low settings. But the issue is discord lags af and ppl don't hear me talk aswell. Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556045 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Author 16 minutes ago, RAS_3885 said: What FPS are you getting? What resolution are you running? Check this out. Suggests trying to limit FPS or turn on v-sync. Tried when the problem started, issue continued I'm sorry.. Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556077 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 4 minutes ago, Viciouszzz said: Tried when the problem started, issue continued I'm sorry.. Even limiting the FPS to something like 60 you still have close to 100 percent CPU usage and stuttering/Discord issues? Be sure to QUOTE or TAG me in your reply so I see it! CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15 Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556091 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Author Just now, RAS_3885 said: Even limiting the FPS to something like 60 you still have close to 100 percent CPU usage and stuttering/Discord issues? I have a 144hz monitor going bellow that is unbearable, tried locking at 144, when frames dropped my game stutters, and yes discord issues still remain, I just guess my pc is trying to pass to the beyond? Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556101 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 1 minute ago, Viciouszzz said: I have a 144hz monitor going bellow that is unbearable, tried locking at 144, when frames dropped my game stutters, and yes discord issues still remain, I just guess my pc is trying to pass to the beyond? As a troubleshooting step try locking to 60 FPS and see if at least the stuttering and Discord audio issues go away. Be sure to QUOTE or TAG me in your reply so I see it! CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15 Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556106 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Author 15 minutes ago, RAS_3885 said: As a troubleshooting step try locking to 60 FPS and see if at least the stuttering and Discord audio issues go away. Same thing Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556134 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 2 minutes ago, Viciouszzz said: Same thing IDK, that doesn't seem right then, but I don't know what else to suggest. I'm wondering if there's something to do with the bent pins you had, even though you fixed them. You should not be having a CPU bottleneck locked to 60 FPS, let alone one that's severe enough to cause stuttering and issues in other applications. Maybe someone else will chime in with some other ideas... Be sure to QUOTE or TAG me in your reply so I see it! CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15 Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556150 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2021 Author 2 minutes ago, RAS_3885 said: IDK, that doesn't seem right then, but I don't know what else to suggest. I'm wondering if there's something to do with the bent pins you had, even though you fixed them. You should not be having a CPU bottleneck locked to 60 FPS, let alone one that's severe enough to cause stuttering and issues in other applications. Maybe someone else will chime in with some other ideas... Thank you for your help tho. I have ideas to change cpu and keep the gpu, just because of the bent pins but idk. I might go dor AMD Ryzen 5 2600 and mobo the Gigabyte B450 Aorus Elite v2. hope that's a good combo for the 3yo 1060. Link to comment https://linustechtips.com/topic/1314679-i-need-help/#findComment-14556162 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
