My friend has recently wanted to get into pc gaming, sadly he play fortnite, could anyone recommend him a full pc build that runs 144 frames on a £600-£800 budget, any help would be appriciated i would have done him a parts list just idk what gpu to pair due to the prices and most not in stock.
https://linustechtips.com/topic/1313750-friend-needs-help/
Check this out, and then folks can help easier...
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1313750-friend-needs-help/#findComment-14547799
Since they play fortnite, which isnt that demanding, a lower end CPU and GPU combo will be fine. Something like a 10100F from intel should do the trick or an R3 3100 from AMD.
For the GPU, as I said luckily Fortnite isnt that demanding so you could probably get something like a 1650 which hits around 100FPS at high no shadows, and if you go to low settings with max distance which is basically the mode most pros would probably play at to increase visability of other players and items, thatll sit at around 180FPS.
In terms of RAM, it depends on the CPU but it should be 16GB as a minimum and for AMD 3000+ MHz is a must, 8 will get by but its very soon going to be an issue. Everything else can be budgeted to fit in your price range. Ive done so below.
Intel:
AMD:
Note I went for a B550 board for AMD, while you can get an A320 board to be cheaper, the upgradability of a B550 board will make it worth the extra cost.
Personally the extra £30 overall for the AMD system will probably be better overall due to said upgrade paths, with AMD allowing multiple generations of CPUs to run in the same socket, which should mean the motherboard should be able to be used for a longer period of time. Intel while cheaper at first doesnt support that many upgrade paths usually and looking at the leaked 11 series 11700k its very underwhelming.
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/1313750-friend-needs-help/#findComment-14547865
GPUs are hard to come by these days. Even the lower end ones.
May her better off buying a prebuilt.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1313750-friend-needs-help/#findComment-14548030
