Hey guys,
Here's what happened: The logical volume that I created on my RaspberryPi4 consisting of 2x3TB HDD drives crashed. Somehow, and I don't know what happened to this day, the second drive got formatted to mirror the structure of the pi, means /boot and / with the same partition-sizes (256M/57.7G) were put out by lsblk. I suspect a crashed mSD-card (I've learned my lesson), but actually, I have no clue.
After trying out about 10 different recovery programs, most of which only found RAW-Data, I stumbled across R-Studio which worked like a charm. Most of my files can be recovered and it provides the correct folder-structure.
Anyway, here I am with about 4-5TB of potentially recovered data with a single question: Where can I store it?
The HDDs work fine according to several pieces of testing software, so I plan to create a logical volume again and restore everything to how it was (now with an additional small backup for the most crucial data at least).
I could not recreate it from lvm's backup file so this appears to be the only solution left.
I've looked around for services with unlimited storage and stumbled across Backblaze. However, it only allows complete drives to be backed up and I would need to upload my data rather piece by piece as I don't have the necessary storage to temporarily store the data plus an image of them. Other cloud services are simply too expensive for the amount of storage and alas, I've already used my free cloud.google trial.
I'm looking forward to read your ideas about that.
Thanks for reading,
Arokan
https://linustechtips.com/topic/1312168-temporary-storage-for-recovered-data/
The slightly-less-than-ethical answer is to buy a large enough external (or two, for redundancy), move the files, recreate the array, copy the files off, and return the drives (or keep them for backups 🤷‍♂️).
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
Yes, buying external hdd for future backups seems like the best idea. You'll need the storage anyway, nothing can be done about it.
Online/cloud is going to be painfully slow and not really cheap for such volume, even for temporary storage.
Also do not assume that because you have correct directory structure data is not corrupted. Do not do anything with source disks until you are absolutely sure you've got all you need.
Thanks for your advice!
I'm hesitant to buy a new drive because actually, I have all the storage I need. I was just not prepared for a crash (learned the lesson).
When it comes to the "slightly-less-than-ethical"-Solution, I can't do it locally because they are not obliged to take the drive back. Different story if I'd order online, but I've heard that amazon is a bit bitchy when it comes to refunding hard drives too.
That's strange.
You either have enough storage for full backup and then you can just use it now, no issues.
Or you do not, and buying it will be useful then.
Also what kind of configuration it was? Mirror? stripe? jbod?
19 minutes ago, Archer42 said:
That's strange.
Oh yeah, I should clarify that. 😄
I've got another 256GB external drive to backup the most important data. Then won't be that f-d-up when this happens again. However, I just plainly want the rest of it back as well. It's not the most important stuff, but still. And if I or someone comes up with a solution, why not. 🙂
Well, a solution that will allow storing data without storage device would be interesting indeed :)
If you want online you can take a look at this.
Rent a machine for a month, setup some kind of storage server there, use it to temporary store data.
But then... it is going to cost you a good chunk of money you could have used to buy external hdd, which you would also get to keep, unlike rented server.
