Ryzen 7 3800x
Hyperx fury ddr 2666 2x8gb
Nvidia rtx 2060 super
Asus tuf x570 gaming wifi
Apevia 800w 80+ gold psu
Corsair spec Delta case
All parts are less than 2 years old minus the ram, and before anyone says anything about the ram speed, it was free.
Anyways, a month ago I was getting crashes in games giving a memory error then would get bsod saying memory issues.
I found that the Xbox game bar was the culprit.  I disabled the app, updated the bios and thought all was well.  This morning I woke up to a bsod and then a no post when the pc restarted saying vga error on the mobo led.  I powered it down, system tried to restore, and another critical error followed by a boot led indicator.
I plan on replacing the ram while I am near a micro center as I need it anyways, but does anyone have any insight as to what could be happening?
On a related note, windows automatic update is off so it isn't a bad update.
Edit, I am currently out of town and cannot look at what bios I am using, but it is the most current beta bios available.
I am also using the most current build of windows 10 home.
https://linustechtips.com/topic/1311739-need-help-seeming-random-bsods-the-no-posts/
