Hello, I am Adam, and I am a PC Builder beginner. I Have just built a Gaming PC, but the monitor says no signal when I boot up.
Specs:
AMD Ryzen 5 3600
AsRock B550M-HDV Micro ATX Motherboard
16 GB Ram (2x8 GB sticks)
ASUS Phoenix 1050ti
EVGA W3 Series 450W 80 plus
AMD CPU Cooler that came with the CPU
512 GB SSD (6gb/s)
I have seen many videos on what to do, and here are some things I tried
-Remove GPU, then reinstall
-reconnect all power cords
-change video cable
-clean the ram sticks
-read motherboard manual carefully
-plugged in 4 pin CPU power
-attached all power connecters
-tried booting up with one ram stick
I have been stuck on this problem for a long time, and I need help. I hope you see this post a couple of hours or 1-3 days after posting this. Thank you for visiting the post.
https://linustechtips.com/topic/1307391-no-signal-problem/
10 hours ago, AdamR said:
Yes the GPU fan and all other fans are spinning.
OK, do you have any debug lights?  Is the video cable plugged into the GPU or MOBO?  Do you have another computer or console you can plug into the monitor to make sure that is working?  Is the monitor set to look at the port you have your cable plugged into?  ie. Direct video or HDMI
https://linustechtips.com/topic/1307391-no-signal-problem/#findComment-14499186
I did test the monitor and video cable.
https://linustechtips.com/topic/1307391-no-signal-problem/#findComment-14504886
If you have another available output port on your GPU you could try that in case you have a bad port.  If not, if you can borrow a GPU from a friend it might tell you if your GPU is defective.  If it doesn't work with a known working GPU, I would lean towards a MOBO problem.
https://linustechtips.com/topic/1307391-no-signal-problem/#findComment-14506079
