Budget (including currency): around 14,000 sek (swedish krona)
Country: Sweden
Games, programs or workloads that it will be used for: Gaming for the most.
Other details: Here are the current parts that I plan on getting.
Ryzen 5 5600X
B550 ATX
2x8GB
RTX 2060
4000D Tempered Glass Mid-Tower ATX Case — Black
I'd like to hear which parts I should change.
https://linustechtips.com/topic/1301805-need-help-with-my-first-pc/
So far I think it looks good. I don't know anything about AMD CPU's so I can't give you any feedback there. However I'm also from Sweden and I'm curious as to what website you're ordering from. Maybe I could find you some good alternatives there that is cheaper than what you have!
GPU: RTX 2080 Super        Keyboard: Corsair K70 MK.2 RGB
CPU: i7-9700K        MouseLogitech G PRO Wireless
RAM: 16 GB Corsair Vengance PRO                                                         Headset: Corsair HS70 PRO Wireless
PSU: CX650F        MousepadCorsair MM500 Extended 3XL
MOBO: Asus Prime Z390-A        ControllerDualSense 5
Case: Lian Li Lancool II        CameraCanon EOS M50
Monitor: Samsung Odyssey G5        CoolingCorsair H100i Platinum
The white Rabbit        MicrophoneTrust GXT 252+
Ye I asked in a discord server and a guy helped me with choosing new parts, thank you for your help though!
