Hello Guys, I want to build for the first time pc, before this I played on prebuilds from stores, I don't wanna overpay again, so i'm trying to build new pc.
Main goal: Gaming/Video Editing/Streaming
So far I got this: https://pcpartpicker.com/list/CVjPcT
Maybe any tips? (GTX 1070 I have already, don't switch it please and I really want ryzen 5 5600x, cuz it's pretty good)
Budget: 800eur + gtx 1070 for 200eur = 1000eur.
Thank you very much!
https://linustechtips.com/topic/1301671-help-me-build-pc-please/
Quite a good build, but I would recommend trying to get a proper brand PSU. One from Corsair/Evga/seasonic etc and not from brands like kolink or gamemax. You don't want a dodgy power supply to kill your system!
exactly, I have seen systems fail thanks to dodgy PSUs in the past, even ones that claimed were " 1000w " and cost me 30 bucks.
So try getting a good psu, you can go through the PSU Tier List here in the forum too.
And another suggestion would be to bump your ram to 3600 mhz as that is the sweet spot for AMD as AMD favours faster speed RAM.
this is the tier list:
[psucultists] PSU Tier List - Power Supplies - Linus Tech Tips
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
Thanks for tip but I already took that PSU from that list, it's in B tier, I think tier B is not bad, right? And I will check better ram maybe.
The PSU OP has is a tier B. Corsair, EVGA and Seasonic all make PSUs ranked lower than that. Yes, they make plenty higher than tier B, but they might not be available there.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Do you think it's bad? I just took it from PSU tier list and it's in tier B.🙈
As far as the RAM goes, 3200 cl16 and 3600 cl18 are both roughly 10ns. If you're going for faster RAM, 3600 CL16 is 8.88 NS, but can be a bit more expensive. I've always had good luck with LPX in Intel and the one AMD build I've done, but there are people here that swear against it.
https://notkyon.moe/ram-latency.htm
Project Hot Box
Oppbevaring
What about Motherboard? Is it fine? It costs under 100€ in my country, I was originally picking ASROCK B450 ATX Pro4, but changed to mATX B550. And if it's not great, what should I change, because my budget is 800 (without Gpu) and this build all together is 800, so if I take more expensive mobo, I should take something cheaper..
I just wouldn't go near any brands like kolink/gamemax/CiT. I've had too many bad experiences from brands like them no matter the tier of PSU they are! Would just be a shame if you spent all that money for the PSU to kill your system!
How much is the b450 tomahawk max in your country? (That's a go to board by many ryzen users!). I've had great experiences with Asrock in the past (had an extreme 4+ on my old athlon) so as long as it's got the feature set you want I would say it's a fine choice!
