3 minutes ago, Yousssa said:
So i downloaded garrys mod and after that my fps has been 62 stable in pubg when it used to be around 130. Battlefront 2 used to be 200 and now is 130.
Help is appreciated
On what disk/drive is Garry's mod installed on? Did you download servers on Garry's mod like DarkRP, etc..? How much space do you have left on the disk/drive your games are installed?
hi, im renata bliss and am ur freestyle dance teacher
I downloaded it on my harddrive (S) it has 1600gb and my ssd has 465 gb. Played on darkrp
Did you try uninstalling GMOD and see if the games came back to normal frames after the uninstallation? Thats probably the most logical thing to do to help determine if GMOD is at fault or nah.
Uninstalled and apparently did nothing.
Oh okay.. gmod is usually a really fuckey game so something small could've been done to some registries. Just use CCleaner to clean registries and try testing frames again.
Cleaned the registries using ccleaner and same thing no change what so ever
Did you try and default the Nvidia Control Panel settings? If yes and nothing changed.. did you try restarting the computer and then seeing if the FPS came back to normal?
This sounds stupid but restarting your computer usually/sometimes fixes these kind of issues and especially after installing a game like Garry's Mod.
I have restarted my computer the first time it did boost my fps in Battlefront from 30 to 130, but no luck doing it again. I defaulted the nvidia panel 3d settings if that is what you mean.
EDIT:
Got pubg running at around 140fps by chaging the max fps from unlimited to screen based. It was unlimited before.
EDIT:
Oh, so did you manage to fix it by that?
Only in pubg Battlefront 2 has the same story
Oh alright... well im really out of ideas. I wish you good luck to solve your issue soon. Stay safe.
