I'm at a bit of dilemma:
I've decided to upgrade my cooling setup as my 10-year-old came-included-with-the-case Molex fans are dying.
I'm not sure what to do, though:
1. Get 1 120mm and 1 140mm fan to put on the back (exhaust) and top (not sure)
2. Get 3 120mm and put them in the back (exhaust), top (not sure), and bottom (intake)
Here is a diagram of my current setup (120mm front intake, 190mm side intake, 120mm exhaust)
And here is option #1 (120/140):
Here is option #2 (3x 120):
I'm not sure which way to orient the top fan - should it be intake or exhaust?
And which one is better - the 120/140 or the 3x 120?
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1296006-what-to-do-for-cooling/
Top fan should be an exhaust, as it would be a complete waste of airflow (the air would be just exhausted again by the another fan) if it's gonna be an intake.
Both options are viable and actually would be the same. 3x120 would be much easier to get to.
Humor me, as you should do.
Daily drivers, below.
Diccbudd PC
AMD Ryzen 5 3600 || ASRock B450M Pro4 R2.0 Motherboard || MSI GeForce GTX 1650 Gaming X 4G || ADATA GAMIXX D35 2 x 8 GB DDR4 3200 MHz RAM || 480 GB Samsung PM981A NVME SSD // 480 GB Pioneer APS-SL3 SATA SSD // 1 TB Seagate 2.5" HDD || be quiet! System Power 9 500 W PSU || Deepcool AG300 CPU Cooler || Skyworth H27G30Q 2k 180 Hz Monitor || Logitech M650 Signature Mouse || Nuphy Air75 v2 Keyboard
Samsung Galaxy A34 5G
8GB RAM, 256GB Internal Storage, 128GB SanDisk Extreme, and you could find the rest of the specs on the interwebz lol
Lenovo ThinkPad L390 Yoga
Intel Core i5-8365U || 8 + 16 GB DDR4 (don't ask, gf bought me the 16 GB RAM as my birthday present lol) || Samsung 256GB SSD
Personal Server: HP Elitedesk 800 G3 SFF
Intel Core i3-7100 || Hynix 40GB DDR4 || 120GB random SSD || 1TB Toshiba 2.5" HDD
Audio
Redmi TV Soundbar || KZ EDX Ultra + KZ APTX Bluetooth Module || JCALLY JM6 CX31933 DAC
https://linustechtips.com/topic/1296006-what-to-do-for-cooling/#findComment-14407653
The bottom 120mm would be almost completely choked (my case has no cable management and most of my cables are stored there, so if I did put one I'd probably stick a fan guard on it), but I could put it in the front.
Front fan is doing fine, though.
I think I'll do the 3x120 as it's $10 cheaper.
https://linustechtips.com/topic/1296006-what-to-do-for-cooling/#findComment-14407665
Rather to put it on the front instead of choking the airflow there....
Diccbudd PC
Audio
https://linustechtips.com/topic/1296006-what-to-do-for-cooling/#findComment-14407681
I've already got a front fan that's going strong.
Just my rear fan is dying and it's responsible for dissipating my CPU heat - which is probably why I have 50-60C idle temps.
https://linustechtips.com/topic/1296006-what-to-do-for-cooling/#findComment-14407684
It's kind of bit too high, tbh. How about the CPU cooler? Thermal paste's good? No clogged airflow on the fins of the cooler?
Diccbudd PC
Audio
https://linustechtips.com/topic/1296006-what-to-do-for-cooling/#findComment-14407705
Arctic MX-4, applied in September 2020.
Fins are clear, fan is a bit dusty but spins freely (hard to clean as it's a SpinQ).
https://linustechtips.com/topic/1296006-what-to-do-for-cooling/#findComment-14407717
