So, I built a new PC after my old PC broke down, and it does post.
The problem however is, that the intake fan which is connected to the SYS_FAN_2 header doesn't spin. the other fan does spin (connected to the SYS_FAN_1 header).
When I switch the connections, (in -> fan_1, ex -> fan_2) the intake fan spins, the exhaust fan doesn't. ==> The one connected to SYS_FAN_1 works, the one connected to SYS_FAN_2 doesn't.
Also the BIOS doesn't show the fan connected at SYS_FAN_2.
This to me pointed towards a faulty header at first, but I got a replacement from the vendor and it has the same problem. I made a bios update to the most recent version.
Is this a known problem with this mainboard or do I have very bad luck getting 2 faulty ones in a row? Or is there a BIOS-setting I didn't see?
If it's a known problem: Do you have recommendations for another mainboard at around the same price tag?
The specs I think are important are:
  • Mainboard: Gigabye x570 Aorus Elite (BIOS version F31, latest)
  • CPU: AMD Ryzen 5 3600 (with the included boxed cooler)
  • BeQuiet Dark Power Pro (750W 80+ gold)
  • BeQuiet Pure Base 500 (with included Fans)
The other specs, if I forgot something:
  • OS: Windows 10 Ultimate 64 bit
  • 2x16GB Corsair Vengeance RGB Pro RAM (3200MHz XMP profile 1)
  • Some GeForce GTX 750 TI (forgot the integrator tbh)
  • Samsung 970 EVO 500 GB boot drive
  • 3 SanDisk SSDs and 2 HDDs
Thanks in advance for any help.
https://linustechtips.com/topic/1294323-fan-not-working/
