So... the other day I was helping my Father in law build a pc for my girlfriends brother and we built everything, but when it was time to power it on everthing lighted up, the fans, the CPU cooler, except the GPU. So we removed the GPU and tried placing it again, didn't work. After that, we forgot the 12V CPU power cable disconnected and turned on the pc, and for some reason the GPU turned on.
So what we know is:
When the CPU 12V cable is connected the GPU doesn't turn on, but if you disconnect it (the CPU 12V cable), the GPU turns on.
Here is the parts list:
https://de.pcpartpicker.com/list/2nZ9F8
The CPU and GPU are used.
https://linustechtips.com/topic/1294157-cpu-and-gpu-power/
