yesterday i finished my Ryzen 5000 build. Everytime i restart or power on one Case Fan stops spinning for 1-2 seconds then powers on again and works normal after this, i already tried 2 different headers on the board, same problem, do i need to worry about that? Otherwise the System is running fine.
Specs:
Case: Corsair 275R Airflow
Mobo: Gigabyte B550 Gaming X V2
CPU: Ryzen 7 5800X
Cooler: Fractal S36 Celsius with 3x Arctic P120 Fans
GPU: RX 6800
PSU: Seasonic Focus PX-850W
SSD: 1TB NVMe SanDisk
SSD: 2TB Sata-SSD SanDisk
Case Fans: 3x Corsair AF120 Red
https://linustechtips.com/topic/1292086-case-fan-stops-while-booting/
I doubt its anything to worry about, if you haven't updated the bios try it.
If you're worried you will need to ask people who have a similar motherboard as its not normal behavior.
