Budget (including currency): 1200-1500€
Country: Switzerland (will buy most of my parts from Germany)
Games, programs or workloads that it will be used for: Gaming only
Other details: want to be able to game in 1440p 144Hz, need bluetooth and wifi
I've never build a PC before so I pretty much had no idea about almost anything.
Because I am really interested and don't just want to blindly go into this without any knowledge I checked a few threads here and did some research and I built something together in pcpartpicker.
I am very open to suggestions and changes to my build.
+ GeForce RTX 3080 600€
Together: 1238€
Monitor: I would also need a new monitor, but didn't have time to research that (price of monitor not included in budget for PC).
I know some parts are very hard to get or extremely expensive at the moment. I am in no rush whatsoever and can wait until they are back in stock
Thank you very much! :)
https://linustechtips.com/topic/1286737-first-gaming-pc-build/
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1286737-first-gaming-pc-build/#findComment-14339462
1 hour ago, HairlessMonkeyBoy said:
CPU cooler: Could I get away with stock cooler on the CPU? I won't be overclocking, so would be great to save some €.
Motherboard: Want to have wifi & bluetooth. Is this one good? MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard
RAM: Is almost 50% higher price to go from 3200 to 3600 worth it?
Power supply: 30% higher price for 50W more and gold instead of bronze worth it?
Nice find on the SSD (won't need a hard drive as 500GB SSD is enough) and the cheaper case, thanks!
https://linustechtips.com/topic/1286737-first-gaming-pc-build/#findComment-14339750
Yup, the stock cooler is fine. You can always upgrade it later if you want.
Maybe this one, it has wifi 6:
https://pcpartpicker.com/product/BXDkcf/asrock-b550mac-micro-atx-am4-motherboard-b550mac
Forgot to switch to Germany. The one you picked looks okay.
RAM: Is almost 50% more expensive to go from 3200 to 3600 worth it?
There is a small benefit. 3200Mhz will get you 98% of the performance and the kit you picked looks good.
No problem!
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1286737-first-gaming-pc-build/#findComment-14339781
