Budget (including currency): $650 usd
Country: United States
Games, programs or workloads that it will be used for: fps titles, work, little bit of CAD
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): explained below.
Back a couple months ago, I built a computer around the Ryzen 3 3200g, with no dedicated graphics alongside it. I bought this 430w psu with the build, as it was a great price and I knew it would be sufficient for the power draw of the processor. Now, I have upgraded to a dedicated graphics card, this Radeon RX 5500 XT, with the same processor as before. Is my current power supply still sufficient? Who should I trust to tell me if it is? If it is now too small for my power draw, what wattage should I aim for to upgrade before I install my new card (keeping in mind I would like to upgrade my processor to a midrange option at some point).
Thank you!
https://linustechtips.com/topic/1285316-upgrading-from-integrated-graphics-help/
